2058
Highlighted
Beginner
RV325: DNS serving for MAC/IP bindings?
Does the RV325 have a possibility to serve DNS replies for local server names? Most @home routers these days have a local device list that they resolve so that there is no need to setup a dedicated DNS. I was wondering if the RV325 can do this as well or that I need to setup an additional server?
1 ACCEPTED SOLUTION
Highlighted
Enthusiast
Hello Steve,
The RV325 does have an option like this, called DNS Local Database.  It is available under DHCP >> DNS Local Database.  This will allow you to setup Name-to-IP bindings without needing an entire DNS server.
Hope that helps, and thank you for choosing Cisco,
Christopher Ebert - Advanced Network Support Engineer
Cisco Small Business Support Center
*please rate helpful posts*
4 REPLIES 4
Highlighted
Enthusiast
Hello Steve,
Highlighted
Okay thanks, I had found that but couldn't get it to work. With your confirmation that this was indeed what I was looking for I finally discovered I had to change the DNS Server mode into "Use DNS Proxy", this wasn't entirely clear to me. Also: The help only explains how to manually modify network settings, perhaps it would be a good idea to also point out there that *if* you are using DHCP, the proxy is an alternative?
Highlighted
When I have that proxy enabled, resolving fails for a whole bunch of external sites. The sites themselves work, as I can resolve them when I either turn the proxy of (and renew the DHCP) or if I use my other internet connection.
Any idea how I can get this problem resolved? I do need the local resolving but if it prevents to from getting to my regular sites it doesnt really add much use.
Highlighted
My challenge is across the VPN and DNS of local device to the core network. The IP addresses are in the 172.16.100.x range. The DNS setting is 192.168.1.1. The routing fails for devices (i.e. network drive) on the 192.168.1.x range. It is like the 192.168.1.1 DNS does not share the details with the VPN devices on a client to Gateway IPSEC tunnel. Not sure if I a missing a routing rule or have an incorrect DNS setting.
