02-04-2015 09:27 AM
Hello everyone, I just got a brand new RV325 for private purposes and so far I have upgraded the firmware to the latest version immediately and most of the stuff runs stable, however I run into a problem.
I have enabled EasyVPN and got it running with IOS/Android/OSX and Windows, however while the router generally seems to run stable the vpn server however stops working after 3-4 hours of uptime. I cannot connect to the VPN server from outside anymore until i go to the vpn settings and save them again which seems to restart the internal VPN server again.
Does anyone have any advice on how to deal with this problem?
02-05-2015 07:32 AM
Ok seems like I have to reply to myself.
I finally found out that the problem is the osx ipsec client, it simply fails on 2 out of three connects, the same goes for IOS, if someone can pinpoint me towards working clients for OSX/IOS I would be grateful.
The funny thing however is that a connection to a CISCO ASA server my employer uses works without a hitch with both clients.
Also the Windows with the ShrewSoft client as well as Android with the integrated VPN IPSEC client works without a hitch with the rv325.
02-05-2015 11:56 AM
Ok I resolved my issues differently, I now have attached a Linux server which serves an OpenVPN access, that works reliably in OSX and IOS.
Anyways, is there a possibility to report a bug to Cisco regarding this? It is strange that an ASA IPSec VPN connection works reliably on OSX/IOS while a RV325 EasyVPN connection does not work properly. Given the install base of IOS this might be a bug worthwhile investigating on the side of CISCO.
02-05-2015 01:44 PM
Hi werner@gmx.at,
If you would like to open a bug case, please call our Small Business Support Center. Contact information is located here: http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Explain to the technical engineer that you would like to report a bug.
Thank you!
Cindy
