01-22-2017 03:39 PM
Hi Everyone,
I'm trying to accomplish something with my RV325 that may be a little out of the ordinary and am not having much luck. I have 2 WAN links (1 is DSL, 2 is LTE) and they operate well in load sharing mode. I've configured a couple of Protocol Binding settings to force high bandwidth devices (Apple TV, etc) to use WAN 1, and everything operates as expected. Now, here's the issue. My DSL connection recently failed without my knowledge (modem failure) and all traffic went out WAN 2 (LTE) and as one can expect, used a lot of expensive bandwidth.
I'd like to find a way that I can prevent this in the future by making either implementing a more stringent Protocol Binding or some other way of preventing certain LAN IPs from even having access to the WAN 2 connection. I think the router is doing exactly what it should by failing over to the secondary WAN, but I'd like to prevent non-essential services (Netflix, etc) from finding their way out the LTE connection.
RV325 firmware: v1.3.2.02
Any help is appreciated.
Thanks.
Dave M
Solved! Go to Solution.
02-01-2017 05:20 PM
Hi David,
Sorry for late reply due to CNY, I just tried several scenario with my RV325 but seems hard to meet your requirements via create ACL, since access rule can't choose outgoing interface.
But you can try to create QoS rule to limit non-essential services outbound traffic
Interface | Service | IP | Direction | Min. Rate(kb/s) | Max. Rate(kb/s) | Status |
WAN2 All (IP) up/down 50(or lower) 50(or lower) enable
Ami
01-22-2017 09:46 PM
Hi David, I think you can put non-essential services in other vlan also with protocol binding and adding access rule to prevent it go thru WAN2, not sure if this fits your needs.
01-23-2017 08:06 AM
Hi Ami,
Thanks for the reply! That sounds like what I'd like to do, but I'm not quite sure how to configure the access rule. Could you provide any more help on that aspect of the setup? I'm familiar with setting up a new VLAN and assigning the non-essential devices to it, but I'm not quite sure how to build the access rule to prevent it from going out WAN 2. Thanks again for any info you can provide.
Dave M
02-01-2017 05:20 PM
Hi David,
Ami
02-06-2017 06:27 PM
Thanks Ami,
I'll give it a try.
-Dave
