RV325 how to assign different Easy VPNs to different specific VLANs for Android Client access.
r.odstrcil
Hello community!
Is there a way how to assign different Easy VPNs to different specific VLANs with Full Channel option for Android Client access?
Background:
I have several VLANs configured on my RV325.
The IP ranges for VPNs is only one for all of configured VPNs - see screenshot with default IPs.
When Android Clinet makes connection, it is not sure, what IP it gets.
That means I cannot use Firewall settings as a workaround (IP to access only a Range of IPs of particular VLANs).
A) Is there a way how to assign Easy VPN to particular VLAN?
I would expect such feature for Cisco product, but I could not find it.
B) Is there a way how to solve it in a different way?
Thank you.
0 Replies 0
