RV325 Router - Inter VLAN Networking.
hfrohr001
Hi Experts, greetings.
I have the following configuration on the RV325.
VLAN 10 (10.10.10.x)
VLAN 20 (10.10.20.x)
VLAN 30 (10.10.30.x)
VLAN 40 (10.10.40.x)
VLAN 50 (10.10.50.x)
Currently, I set the INTER-VLAN to ALL those VLAN, and I'm able to see any host in this network.
But, in a near future, I'd like to have:
1) Disable the INTER-VLAN (so the hosts can not see others hosts outside its sub-net)
2) be able to configure specific IP from one sub-net to reach another specific IP from other sub-net.
    example: IP 10.10.10.40 (VLAN10) to be able to communicate with IP 10.10.30.40 (VLAN30). (others IP's from VLAN10 can not reach VLAN30, and vice-versa)
All the hosts are connected through a SG200-50 switch. (the router is connected to SG200, using TRUNK with all VLAN).
Is this configuration possible by using the RV325? (Firewall or static routes settings?)
Henrique
Simon Brooks
I'm not familiar with this device but disabling inter vlan routing will ultimately stop traffic routing between your interfaces.  You would need to re enable this and the configure access lists for your requirements.
Simon Brooks
