RV325 Router Inter Vlan Routing problem
mail
Help.....
Can’t Access equipment on Vlan 1 from Vlan 20
Case:
Cisco RV325 Router (newest firmware)
Vlan 1                192.168.1.0/24 DHCP
Vlan 20              192.168.2.0/24 DHCP
Equipment:
Asus AP             192.168.1.16                                 Static IP             Connected to Port 1
Default GW        192.168.1.1
Synology NAS    192.168.1.15                                 Static IP             Connected to Port 2
I did this:
Started with factory defaults:
Created Vlan 20 and checked that DHCP is 192.168.2.1/24
Enabled Inter Vlan routing on both Vlans
Untagged Port 08-09-10-11 to Vlan 20.
Untagged the rest of the ports to Vlan 1 (was default)
Connect my pc to Vlan 20 on Port 08 and got IP 192.168.2.100 from DHCP.
But I can’t Ping or access AP nor NAS on Vlan 1.
But this all works perfectly on my Cisco router RV130 ???
rockmaker99
Hello i have the same problem did you fix it ?? thanks :)
