RV325 Static IP Not Working
jenius
After a factory reset, static IP settings won't fully load websites. Was working fine before reset. Connected laptop and several routers with the static settings and web works fine. Turned off "Enable Network Service Detection" under System Management | Dual WAN. The browser bar loads about 25% then freezes and won't proceed. Is there anything else that needs to be configured for static IP to work? I'm on latest firmware...
2 Accepted Solutions
marce1000
  - Check logs on the RV.
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
balaji.bandi
Remove the WAN Connection from Router. reload the Device - check is the Router can access web GUI as expected.?
there were some exploits on these models, so check no outside connection allowed for web GUI and https access. remote management make it Lan IP range.
then connect to WAN and check, do you have dual WAN connection or one ISP ?
BB
8 Replies 8
marce1000
 M.
It’s showing that the connection is up and then it fails.
Got a new static IP from ISP and all is well. Thanks for your help.
balaji.bandi
BB
One ISP
Remove ISP connection and see you able to access the GUI
BB
I do…
