08-06-2019 06:51 PM
I am having issues with VLANs in that they don't appear to be isolating anything and allowing traffic/management freely.
Setup:
I have 2 specific VLANs, shown as Alpha and Beta below. Alpha is on Port/Lan 14 and Beta is on Port/Lan 7. As can be seen in the screenshot below, Inter VLAN routing AND Device Management are set to DISABLED on BOTH VLANs.
However, I am able to ping any host machine from Alpha to Beta and vice versa despite Inter VLAN Routing set to DISABLED. I am also able to access Device Management from both VLANs despite being set to DISABLED.
I am running the latest firmware v1.4.2.22 (2019-04-02).
Did I miss some buried setting somewhere or is the RV325 not doing what it's supposed to do? Input appreciated.
Solved! Go to Solution.
08-07-2019 02:49 PM
Update: The only available firmware prior to the latest/current is 1.3.2.02 dated from 2016 so gave that a whirl. Side effect is downgrading resulted in a complete router reset -- settings and all.
Good news is that it worked with the same configuration as above. Bad news is because all settings were also reset, I don't know what caused it the problem originally. Ultimately a full reset via the firmware downgrade and setting everything back up, while painful, did the trick. I then upgraded it back up to 1.4.2.22 and it still worked.
Thanks for the confirmation Jo.
08-07-2019 07:35 AM
In my case it works just fine.
08-07-2019 02:49 PM
08-08-2019 03:47 AM
Sorry for the hassle.
Jo
08-07-2019 10:45 AM
Hi Joe,
Appreciate the feedback/data point. I'll try it with your earlier firmware version and see if it makes a difference.
Best,
Dan
