Get the latest new and information the November issue of the Cisco Small Business Monthly Newsletter
331
RV325 - VPN does not work anymore after first restart
I have reconfigured the router many times and everything works fine until first reboot. VPN is no longer working no matter what I am trying.
Error in log is: Tunnel Authorize Fail - no connection has been authorized with  policy=AGGRESSIVE+XAUTHPSK+XAUTHSERVER
VPN is configured as EasyVPN with full tunnel.
If I do factory default and configure again, VPN works again until first reboot.
Firmware version is 1.4.2.22
Any idea?
Many thanks.
1 ACCEPTED SOLUTION
Re: RV325 - VPN does not work anymore after first restart
Hi all,
I have no contract for support, therefore I got no help.
Anyhow, I have downgrade the firmware to 1.2.1.14 and evrything works fine. I can connect to VPN after the restart, I have checked also with IPhone.
Firmware version 1.3.2.02 does not work either. I do not know if one of the version 1.4.x.x will work, but I will not try anymore.
Solution: Downgrade to 1.2.1.14 if you want EasyVPN to work.
3 REPLIES 3
VIP Advisor
looks odd as per the description you have mentioned here.
please do contact SMB support, they can investigate for you.
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
BB
*** Rate All Helpful Responses ***
Thanks for hint.
If I force another save on WAN1 then I can have VPN for 10-15 seconds. No VPN connection after that.
Could be related with "Connected(Inactive)" state of WAN1?
Thanks.
Hi all,
