611
Highlighted
Beginner
RV340 Active Directory authentication
I have problem with remote authentication with AD. The same setting that worked on the RV320 / 325 does not work on the RV340 / 345.
Looking at the domain controller security event log, there is a log on during the VPN connection, but it ends as a login failure.
In the router event log, invalid credentials are logged.
Does anyone already know the solution?
I am working with Anyconect and through LocalDB everything works.
AD Domain Name: atuainfo.local
Primary Server: 192.168.8.2    Port: 389
User Container Path: cn=users,dc=atuainfo,dc=local
RV340 Log:
log_sslvpnac: facility=SslVpn;msg=ERROR sslvpn_aaa_stubs.c.107[747C2470] sbtg_authorize: user or passowrd not correct.;
log_sslvpnac: facility=SslVpn;msg=DEBUG sslvpn_aaa_stubs.c.105[747C2470] sbtg_authorize: ret 10.;
sslvpnd: pam_krb5(anyconnect-vpn:auth): (user "xxxa") error reading keytab /etc/krb5.keytab: Key table file '/etc/krb5.keytab' not found
1 REPLY 1
Highlighted
Did you figure out what this was?
