05-18-2021 10:30 PM
I recently purchased RV340-K9 V05 dual WAN router. I have upgraded the firmware to the latest. Current Firmware Version: 1.0.03.21
dnsmasq: exiting on receipt of SIGTERM
I also see that the router CPU gets to 100% and router becomes non-responsive for a minute.., with my internet connectivity getting distrubed.
Anyone else seen this issue?
Unmesh
05-19-2021 12:23 AM
- Should be considered as a bug , raise a TAC case :
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
M.
05-19-2021 12:39 AM
Looks like I can not open TAC case online, with only specific IP ranges having access to open a case online.
ATTENTION: Network changes that may affect access to some Cisco applications
05-19-2021 01:00 AM
Hi Umesh,
Please go ahead and call STAC by phone.
Martin
05-19-2021 01:03 AM - edited 05-19-2021 01:04 AM
Just called and they asked me to send email to tac@cisco.com, so did that.
But just curious to know if anyone faces this issue with RV340 with latest firmware upgrade. (or otherwise).
05-19-2021 01:22 AM
Hi Unmesh,
Did you experience the same issues with the previous firmware version? What is your internet connectivity type? Have you made any changes before the upgrade?
Martin
05-19-2021 01:31 AM
I just purchased this router, and the existing firmware was too old, so upgraded to latest immidiately. Not sure if the previous versions have this issue.
05-19-2021 01:43 AM
What is your Internet connectivity type?
05-19-2021 02:02 AM
Its dual WAN, 1 PPoE connection and the other is through fiber internet.
