04-29-2021 10:29 AM
Seems like every time I power cycle the RV340, it loses the license key. Requiring my to reregister the device.
I enter the key each time and ensure that I have saved the configuration. But it does not seem to retain the registration between reboots.
Any ideas what is causing this?
04-29-2021 04:48 PM
Make sure apply for the License and SAve and commit the config.
04-29-2021 05:15 PM
Yes,
I have done that every time. As well as saving the configuration as a backup.
When I restore the backup, the registration key is also not restored. So unsure if I need to edit the XML to force it in there.
04-30-2021 08:09 AM
Hi William,
I'm sorry you're encountering this issue. The device should be storing the key. Which license are you trying to add?
As a heads up, you may create a case with TAC to help troubleshoot this issue, if an RMA is required they can also help with that.
Corey
04-30-2021 09:38 AM
I'm using the Security License.
Sometimes it will retain the license after a reboot, but it's very intermittent. Soft reboot it keeps it, hard (power) reboot it doesn't.
If I have to replace this thing I may just upgrade. I do miss having a CLI.
04-30-2021 10:14 AM
Hi William,
That is odd, the most similar issue I came across was in the release notes for an old 2018 firmware (v 1.0.02.16 - link). I wouldn't think you're running that old of a firmware but it does happen. One more question - is the license associated with your smart account? Link to corresponding article.
I miss having a CLI for this series as well, the follow up router to RV34x wont be out for awhile but since its still in development I will share your feedback.
04-30-2021 10:28 AM
Yes, the license is associated with my smart account; I reentered the key on the 29th after it dumped it last time.
LS-RV34X-SEC-1YR=
Smart Software Licensing Status
Registration Status:
Registered (Apr 29, 2021)
License Authorization Status:
Authorized (Apr 29, 2021)
Smart Account: ACM - Nat
Virtual Account: DEFAULT
PID: RV340-K9
Export-Controlled Functionality: Allowed
04-30-2021 10:31 AM
Forgot.
I am running the latest firmware. I'm sort of paranoid that way.
Firmware Information
Firmware Version: 1.0.03.21
Firmware MD5 Checksum: a7a796f915dcff7fdd1afe8a59da9ad3
04-30-2021 10:57 AM
Hey William,
Everything looks normal to me, if you purchased the RV340 in the past year you will be covered for a TAC case - link to submit.
If you're out of warranty on that end let me know and I will continue to try to narrow down the issue. If you do go the TAC route, please follow up with the solution. Please let me know if I can help with anything else!
Corey
04-30-2021 11:03 AM
Yup, outta warranty.
if Im forced to, I guess I could spring for a RV345 off amazon and move the license to it.
04-30-2021 11:37 AM
Bummer about being out of warranty. I'll ask around to see if anyone has any ideas for you. It may be Monday before I get the right set of eyes on this issue though.
04-30-2021 11:49 AM
Thanks! I appreciate it!
04-30-2021 12:21 PM
Hi William,
Most probably the portal won't let you raise a ticket because you don't have an active support contract. Please open a tech support ticket by contacting STAC through one of the following phone numbers https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
The RV34x series come with Cisco LLW so opening a support ticket would not be a problem.
Martin
