RV340 inter VLAN routing
YIJang19667
Dear all,
I'm a beginner of cisco router.
I have RV340 and trying to make two VLANs with inter-VLAN routing.
Firstly, I'd made two new VLANs as like as follows.
Second, I've set access rules.
With this setting, I wished two PCs can communicate with the other PCs in other VLAN.
In VLAN20, "ping 192.168.30.1" is successed.
In VLAN30, "ping 192.168.1.1" is successed.
But, ping to PCs in VLAN had been failed in both sides. (PC in VLAN20(192.168.1.233) ping to PC in VLAN30(192.168.30.81))
Can anyone help us to solve this issues?
I've searched very long time to solve this issue but most of informations of inter-VLAN routing was for other devices of CISCO.
Thank you!!!
ozo@smartbe.be
Regarding the posted config, you have to make sure, VLAN20 is connected to LAN1, VLAN30 is connected to LAN3. Then pinging PCs are supposed to work with this config if local FWs not running on PCs.
Thank you ozo!
As you mentioned, LAN1 port is used for VLAN20 and LAN3 port is used for VLAN30.
After some hours passed, ping to devices in other VLAN works well. (But, I didn't do anything... T.T)
However, whatever ping successed but couldn't connect to target devices. (Ex: connect to web server)
I'll try to find what am I wrong with current settings.
Thanks again ozo!
not sure but try to exclude VLAN1 from both LAN1 and LAN3
Thank you ozo!
Sorry for that it doesn't worked as we expected with your comment. VLAN1 is excluded from VLAN20 and 30 but not worked.
