Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
872
Explorer11
Beginner
RV340 LAN LAG Aggregation
I'm using the RV340 router. I'm wondering if it works to use LAG1 with a dumb switch. What does LAG1 actually do? How does it aggregate the connection?
Thanks!
7 REPLIES 7
balaji.bandi
VIP Expert
LAG does not work with Dumb switch/Hub, it required LAG compatible Switch.,
LAG- Link AGreegation  - means  it combines the 2 X link to 1 = example 2X 1Gb link = 2GB Link
BB
How to Ask The Community for Help
What do you mean by "LAG compatible"? The RV340 uses "static" bonding, so I'm not aware of any protocol requirements like with LACP.
RV Model does not support LACP, it supports static(not dynamic) link aggregation with Trunk option with the neighbor device/Switch.
BB
Thanks. This is an area where the documentation could use improvement. It says almost nothing about this feature and it would be helpful to understand.
So, to clarify, this is not a fallback solution (passive) but an "active" bond where the ports are added together in a trunk. Correct?
Depends on how you configure both side (RV with partner device)
BB
Also, is it layer 2 (based on MAC addresses)? Layer 3? Both?
Thanks.
