RV340 routing and application statistics
AlKor
RV340 sw 1.0.03.15
SG350 sw 2.5.0.79
Didnt work statistic. Show one random ip from network and show it as sg350 switch
Network diagram:
RV340 settings:
SG350 settings:
When RV340 was the gateway for the old network 192.168.1.0 / 24 the statics was OK.
Now i switch network to SG350 and SF220 switches
What wrong with settings? All work ok except statisctics
AlKor
There will be no comments from Cisco?
Jo Kern
As a general hint I recommend if you need support from Cisco urgently to open a support case here:
https://community.cisco.com/t5/regional-service-support-options/bd-p/4626-discussions-smb-support-country
This will assign a case number and your question or problem is being tracked.
For your question below please specify what exactly is not working.
It seems you clicked on"application statistics" and then on traffic type "other"
Can you click on "Client Statistics" to see if the RV340 collects infos about the detected hosts ?
The same, one host in list
IP always random, mac is from SG350 GE10 port.
All traffic types show as 1 client, not only "other"
