11-19-2020 06:53 AM - edited 11-19-2020 06:54 AM
I have been trying to login to the RV340 admin interface lately but it doesn't work. No matter I enter the correct password or the wrong password, the icon next to the login button just keeps spinning indefinitely. If I click on the username field in the meantime, the icon disappears but nothing else really happens.
Some other details:
Has this happened to anyone, and how did you guys solve it?
Solved! Go to Solution.
11-20-2020 03:04 AM
Hello PlyrStar93,
Thank you for your input and detailed description. It seems that the HTTP/HTTPS server on the RV stuck preventing access to the device web GUI. Once you restart the device you can enable the Remote Syslog Server and enable Category "All" on Log Settings. This way you can gather any suspicious behaviour if this happens again and find eventually find the root cause. You can use TFTPd32 as a Syslog server.
Martin
11-19-2020 08:33 AM
Can you see what is the led status (PWR, DIAG, LINK/ACT of WAN1, WAN2, and LAN 1-4) on the RV340 front panel? Do you have the device up and running? Any network/Internet interruptions or network degradation issues? Have you restarted the RV?
Martin
11-19-2020 02:21 PM
Hi Martin,
As of now I can only access one out of the two locations. For this location, everything seems okay--
PWR = on
DIAG = off
WAN1 = on
WAN2 = off (WAN2 is not connected)
LAN1 = on
LAN2-4 = off (not connected)
Devices is up and running, internet connection seems good so far.
Due to the actual environment, I cannot restart the router yet but I will try to find a window on Saturday (two days later from now) and report back the results.
I don't know when or if I can find a time to head to the other location to reboot it, but their internet is fine from what I can tell, there is also VPN connection between the two locations which is up. Since both locations are having the same issue, I am concerned that even if I bring it back by restarting, I may encounter this problem again in the future.
Thank you.
11-20-2020 03:04 AM
Hello PlyrStar93,
Martin
11-21-2020 10:37 AM
Thank you Martin, I power cycled the router and the problem resolved for now. Maybe I should set up a reboot schedule but I can't seem to find the relevant settings. I will also look into the syslog server as you suggested.
Another remark I have is this router had IPv6 enabled and the CPU usage was extremely high most of the time (~60% when it's "low" and can easily go to 100%). The sustained high CPU load may have killed off the router's HTTP(S) server but it's just my guess. I disabled IPv6 on my WAN port and the CPU usage decreased significantly (it's now sitting at 10%--20%).
I will have to see what I can do with the other location, likely find some other suitable time to head to there and power cycle it.
02-17-2021 12:05 PM
I have same issue with this model
Power cycle and syslog sems to be VERY GOOD SOLUTION!!! REALLY?! WTF?!?!?!?
02-21-2021 08:26 PM
as far as I know the Username field is case sensitive so just try logging in with "Admin" instead of "admin"
02-22-2021 05:45 AM
It's not that problem.
Power cycle only helps - great solution from cisco enginer!
02-22-2021 06:43 AM
02-22-2021 06:52 AM
"...Once you restart the device you can enable..."
02-22-2021 07:32 AM
If you read the whole message again you will see that with saying "Once you restart the device" I meant that he must restart first because apparently the HTTP/HTTPS server stuck so to get back and login to the device and enable the syslog server he obviously has to restart it. This is not offered solution to that problem.
02-22-2021 11:48 AM
Ok, the ticket is marked as resolved, so my question is where is the solution??
02-22-2021 01:08 PM
There is not yet a fix or a solution to this type of behaviour. We do not have filed such issues with the RV in our database nor we have cases created with the TAC. I would advice if the problem persist to open a case with TAC.
Martin
08-31-2022 05:12 AM
Try the following procedure:
1. Unplug Router’s power cord
2. Plug the Router in
3. After 30 seconds, unplug the router
4. Repeat steps 2-3 for 5 more times After the 6th time, the router should be accessible.
08-31-2022 05:22 AM
Do I have to stand on one foot while drinking a beer too? This isn't a solution, this is a temporary work around. Not to mention my routers are all in the field at customer sites. I'm not about to roll 160 trucks so a tech can reboot a router 5 times. If I roll a truck, it will be to replace the router with a Fortinet router. Cisco is not what it used to be.
