RV340, Web Login Disabled on RADIUS
I am currently running an RV340 on 1.0.03.20.
Everything is working as expected except that my RADIUS logins are returning web login disabled even though this option is set to either read-only or administrator. I can see that the data is passing through the firewall server and hitting the radius environment. I have created the groups in RV340 to match the AD security groups exactly and it has been applied to the user attempting to login.
What am I missing to make this work? Why am I getting this error?
Thanks!
balaji.bandi
this required more deeply understand and check each step done correctly. ( i re-call some time back doing some other device - it works full access or read-only access) - this is to do with group and radius configured correctly.
follow the below guide for reference maybe you followed(just to help you)
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb5492-configure-and-manage-user-accounts-on-an-rv34x-series-router.html
BB
