11-23-2020 07:38 AM
Hardware: RV340W running Firmware 1.0.03.20
In my captive portal instance, I have set the parameter "Idle Timeout" to "0" as I don't want any timeout. However, when someone successfully logs in to the captive portal, they are kicked out immediately and asked to log in again. If I increase this value, they are not kicked out immediately.
Basically the zero is being interpreted as 0 seconds, literally, instead of unlimited, even if the field clearly says "(Range: 0-1440, 0 means unlimited)"
This is clearly a bug.
Anyone else having this issue?
12-17-2020 08:06 AM
Hello Ignacio,
We do not have similar or such a case in our database. Can you please try to reconfigure the captive portal meaning delete the configuration save it/apply and restart the router. Then reconfigure the captive portal and set the idle time to 0 at the end, apply and restart again.
Martin
12-21-2020 07:07 AM
