06-24-2018 12:01 PM - edited 03-21-2019 11:12 AM
We have a small business network with a Netgear device.
Now we are migrating to a RV345(1.0.01.18) with :
In the DMZ, we have two apache web and ssd servers that filter the request based on IP address.
What is the configuration to have the originating ip address between DMZ/VLAN2 ?
Giles
06-26-2018 11:44 AM
It seems that the router is doing NAT between VLAN2 and DMZ.
Is it possible to disable it ?
06-26-2018 12:43 PM
I would not run 2 untagged VLANs since you can only have 1 default VLAN. Make 192.168.2.0 tagged. The other issue is 192.168.100.1 is usually your modem's web page access. You might want to use a different IP.
06-30-2018 09:26 AM
I changed the 2 configurations : still doing nat.
I tried traffic between VLAN1 and DMZ : also nating the addresses.
I searched in the web console, I didn't find anything about NAT between VLANs and DMZ.
Did I miss something ?
