RV345 Static DHCP not working on v1.0.02.16
Hello
I'm trying to add an entry to the static DHCP table (which is empty), but the mac never seems to be valid. I've tried with multiple (valid) MACs, and removing the dashes and lower vs upper casing. But i still get the red outline on the textbox.
For debugging purposes i get "ng-invalid ng-valid-maxlength ng-valid-grid-invalid ng-touched ng-dirty ng-valid-parse ng-valid-required ng-invalid-mac-address" as a css class on the actual textbox
Hi mikael.gidmark@slowdays.org ,
Try separating the values ​​of the MAC address with=   :
With this, it should be ok
6 Replies 6
luis_cordova
HI mikael.gidmark@slowdays.org ,
Could you share a screenshot of what was done and the error indicated?
As you can see the mac is red and the apply button is disabled. Of course i use a correct mac adress and switched it out with 1s
Try checking with any different IP pool also use the right MAC address of the PC
If you found my answer to be useful please do not hesitate click on the Star button and answered.
What do you mean with different IP pool? I've tested with several IPs, and MAC addresses
Thank you!
