ANNOUNCEMENTS
  • New Firmware Available for the RV340 Series Router Family! posted Apr 30, 2019
This includes the RV340, RV340W, RV345, and RV345P. To learn more and get the latest Firmware version click here
  • Important Update: Cisco RV340 Series and Cisco AnyConnect Secure Mobility Client posted Nov 10, 2018
The RV340 Series supports Remote Tunnel Termination of the best-selling and easy to use Cisco AnyConnect Secure Mobility Client... read more
313
Beginner
RV345P Disable web remote access
Greetings
      I have a question for the group.  I failed a network validation scan for the credit card scanner that we use. I failed because the web remote management interface has a few vulnerabilities, self-signed cert, known java weakness. The quick easy answer is to just turn off the remote access interface. IF I need to turn it back on how would I accomplish this? Can I re-enable the wen interface from the CLI?
thanks in advance
6 REPLIES 6
Beginner
Re: RV345P Disable web remote access
Of course, You can disable and enable remote managment.
But CLI is not work, only web managment in this model.
Beginner
thank you for your reply. Once I turn off remote management. How do I get back in? Will be able I access the webpage if I am sitting on the LAN?
Beginner
Yes. Inside LAN access will work.
You can use http and or https and set port for LAN access.
Default is https and port 443
Thanks for your post.
Yes you can disable/Enable remote management in Rv34x router. And still get an access to Rv340 from LAN.
As for now Rv34x doesn't have CLI access.
Thanks and regards,
Mridul
Cisco SBSC
Highlighted
Yes you can disable/Enable remote management in Rv34x. And still get an access to Rv340 from LAN connected port.
As for now we do not have CLI access available in Rv34x.
Thanks and regards,
Mridul
SBSC
We are working on many of the vulnerabilities by addressing the Linux kernel and libraries in upcoming sw releases.
You can re-enable the Remote Access using the local Web interface or accessing the router via FindIT Network Management.
/Jo
