04-21-2017 02:09 AM
Can anyone from Cisco clarify how to disable the SPI on the new RV34X models? It´s causing a lot of problems in our environment, on the old RV32X models, there was a checkbox, on the newer ones there isnt.
05-10-2017 07:43 AM
My name is Kristian and I am one of the engineers from the Small Business team.
Unfortunately, the RV34X routers do not support the functionality to disable SPI individually. This is a device limitation and in order to disable SPI you will need to disable the whole Firewall functionality.
What I can suggest is to contact our support center to explore whether it is possible to open a feature request for this particular issue.
Hope that helps,
Kris
05-11-2017 01:03 AM
Hello, even with FW disabled, SPI stays on and the router keeps inspecting the packets, which causes communication problem with various web services our clients use.
12-25-2020 06:02 AM
I hope this helps you or the others who have similar issue. I disabled the SPI by downloading the XML file, and change the SPI value on the file, from "true" to "false". Then I save the file and uploaded it to the router.
