RVL200 and Windows 7 do not work
mika22149
Hello everyone,
I´ve searched a lot in all the available communities to find a solution.
Tried everything .... beginning with updating to actual firmware, installing C++Redistr and all other tips I found.
eg there are no ssldrv.* in the assumed directories .... there is a certificate which is outdated in the 1920th (lol) ... it´s true.
Phone support is not avail .... because we use it a couple of years .... with xp and vista there is no prob
Is someone able to help?
Perhaps there is a usefull handout/whitepaper available?
I´ve followed this link, but that did not work:
http://www.cisco.com/en/US/docs/routers/csbr/rvl200/release/notes/RVL200_V1.1.12.1.pdf
regards
Mika
jasbryan
Level 6
Level 6
Mika,
Yeah windows 7 has been a pain lately since java has rolled out several updates. The C++Redistr 2005 is one work around for another router SA500 (SSL vpn trouble). Currently with these production units engineering is working on a fix within the next firmware release. Since the RVL200 is EOL/EOS don't think this problem will get fixed. Most customer don't have this problem until they run all the updates for windows 7 after that SSL broken. Its time to upgrade to a production unit so that windows7 will be fully supported.
Jasbryan
