Hi Folks,
Does anyone know where to find a good explanation of the QoS configuration approach for this device ?
The Device Help Files are very limited in their explanation and the Admin guide is not much better.
I've searched through Web Sites, but none of them describe how the Router treats packets across the interfaces.
How does it queue with CoS VS Trusted Ports ??
How does it treat packets from each LAN port destined for the WAN side ?
How does it treat packets in the reverse direction ?
Derek
Hello Mr. Alex,
If you ask for a good site with information about configuration step by step, I recommend you the guide me section that you cold access on the right site of this page. Includes explanation, examples and configuration step by step.
Also you could find it on the next link:
http://sbkb.cisco.com/CiscoSB/Loginr.aspx?alt1=&pid=4&eroute=Super
And regarding to your questions let me share with you th next links with the information found ABOUT QoS ,
I hope this information helps you.
Diego Rodriguez
Cisco network engineer
Thank you
