04-17-2013 05:11 AM
I have a RVS4000 and I would like to setup a Ping monitoring from the outside to a device behind RVS on lan network. I have created a rule to allow a service PING for range from WAN 46.xxx.xxx.xxx - 46.xxx.xxx.xxx to host 192.xxx.xxx.xxx but unfortunately this is not working. I can confirm that I can ping host 192.xxx.xxx.xxx from diagnostics on RVS. Is there something that I'm doing wrong ?
Thanks in Advance.
Rob.
04-19-2013 02:24 PM
Hi Robert
Thanks for using our forum, my name is Johnnatan and I am part of the small business community, in order to allow the ping from outside to your device, please go Firewall>Basic Settings and disable "Block WAN Request". i hope this helps you.
“Please rate useful posts so other users can benefit from it”
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
04-20-2013 02:28 AM
Hi Jonathan,
But this only would allow a ping to the RVS it self not to the device on LAN network I have tried that and thought that I have found solution but when I disable the device on LAN the ping is still working meaning that it goes no further than the RVS itself.
