RVS4000 WAN VLAN tagging.
racerxoffl
Beginner
Beginner
I have upgraded this device to Firmware Version: V2.0.2.7 (yes its a v2)
As far as I can see it is missing a critical function; I can not put a tagged VLAN on the wan interface. I intended to use this in router mode with a static wan and all firewalling disabled as my CPE equipment on a 100mbit metro-e.
The provider requires the traffic be tagged on the CPE side. I did not want to use a low end dd-wrt device (who's gui only supports upto vlan 15 but you can define higher by hand) as it is not "standard" and supported. I like to provide clean solutions that can be maintained by persons other then myself if needed.
Is there any way to access the CLI on these small business routers and accomplish this by hand?
Thank you.
Don
0 Replies 0
Recognize Your Peers
