09-08-2014 09:30 AM
In my lab I am trying to leverage IPv6 intervlan-routing on the SG300
Why isnt it working?
09-08-2014 09:58 AM
The address space you are using seems to be Private address space (Unique Local address space fc00::/7). This address space may not be completely routable.
https://learningnetwork.cisco.com/thread/46147
Can you try a different address range and see if that helps?
Nagaraja
09-08-2014 01:48 PM
I had chosen to use a ULA address since it was for a lab and had no need for internet access via ip6
I'll see what happens when I assign some global addresses, and report back
09-08-2014 03:38 PM
Using global ip's did not work
I used the following on the switch
2001:0:0:1::1 /64
2001:0:0:2::1 /64
2001:0:0:3::1 /64
and I used the following on the clients,
and the gateways were adjusted accordingly to the switch ipv6 addresses
2001:0:0:1::11 /64
2001:0:0:2::22 /64
2001:0:0:3::33 /64
09-08-2014 04:54 PM
09-08-2014 06:52 PM
I did more digging
Looking at the data sheet for the sg300, I see this
http://www.cisco.com/c/en/us/products/collateral/switches/small-business-smart-switches/data_sheet_c78-610061.html
Layer 3 |
IPv4 routing | Wirespeed routing of IPv4 packets Up to 512 static routes and up to 128 IP interfaces |
Looking at the data sheet for the sg500
http://www.cisco.com/c/en/us/products/collateral/switches/small-business-500-series-stackable-managed-switches/c78-695646_data_sheet.html
Layer 3 | |||||||||||||||
IPv4 routing | Wirespeed routing of IPv4 packets Up to 2K (2048) static routes and up to 256 IP interfaces | ||||||||||||||
Wirespeed IPv6 Static Routing | Up to 2K (2048) static routes and up to 128 IPv6 interfaces
the sg300 just broke my heart =(
