shared printer between VLANs RV320
eddievan
I have a Cisco RV320 with 3 VLANs:
VLAN1: 192.168.0.1/24 sales
VLAN25: 192.168.2.1/24 IP printer
VLAN100: 192.168.3.1/24 accounting
Port 1 is for VLAN1 and goes to the unmanaged sales switch
Port 2 is for VLAN25 and goes to the IP printer
Port 3 is for VLAN100 and goes to the unmanaged accounting switch
PCs in sales (VLAN1) and accounting (VLAN100) both require access to the printer (VLAN25) but should never have access to each other.
Does this require a firewall rule or is there a configuration in Port Management-VLAN Membership that would accomplish this? If it can be accomplished through VLAN, what settings should be used for Inter VLAN Routing, tagged/untagged/excluded settings for each?
Jorge Obregon
Hello Eddievan,
Thank you for contacting Cisco Small Business.
Just the Inter-vlan configuration will allow traffic between all vlans. To restricts traffic from one vlan to another one you might need to configure the access rules.
You can give us a call to 1866-606-1866 and open a support ticket so any available engineer can help you to accomplish that based on the specific network.
balaji.bandi
yes it required ACL / Rules for allow and deny.
here is the document start with :
https://community.cisco.com/t5/small-business-support-documents/access-rules-configuration-on-rv320-and-rv325-vpn-routers/ta-p/3172514
BB
