12-06-2013 08:15 AM
Hello Experts,
I am trying build a site to site VPn between RV082 and cisco ASA but with no luck, maybe I am missing something. Below is the configuration from both RV082 and ASA. Please help!!!
============Cisco ASA============
access-list CRC_McMahon_TX extended permit ip any 192.168.14.192 255.255.255.192
access-list No_NAT extended permit ip any 192.168.14.192 255.255.255.192
crypto ipsec transform-set DES_ONLY esp-des esp-md5-hmac
crypto isakmp policy 114
authentication pre-share
encryption des
hash md5
group 1
lifetime 10000
crypto map CRY_MAP 130 match address CRC_McMahon_TX
crypto map CRY_MAP 130 set pfs
crypto map CRY_MAP 130 set peer 68.179.52.113
crypto map CRY_MAP 130 set transform-set DES_ONLY
crypto map CRY_MAP 130 set security-association lifetime seconds 10800
crypto map CRY_MAP interface outside
crypto isakmp enable outside
tunnel-group 68.179.52.113 type ipsec-l2l
tunnel-group 68.179.52.113 ipsec-attributes
pre-shared-key **********
===========RV082=================
file attached
Thanks in advance!
12-06-2013 08:30 AM
Logs from RV082:
Dec 6 08:29:09 2013 | VPN Log | (g2gips0) #3931: Peer ID is ID_IPV4_ADDR: '64.141.106.4' |
Dec 6 08:29:09 2013 | VPN Log | (g2gips0) #3931: [Tunnel Negotiation Info] Main Mode Phase 1 SA Established |
Dec 6 08:29:09 2013 | VPN Log | (g2gips0) #3931: ISAKMP SA established |
Dec 6 08:29:09 2013 | VPN Log | (g2gips0) #3932: initiating Quick Mode PSK+ENCRYPT+TUNNEL+PFS {using isakmp#3931} |
Dec 6 08:29:09 2013 | VPN Log | (g2gips0) #3932: [Tunnel Negotiation Info] >>> Initiator send Quick Mode 1st packet |
Dec 6 08:29:09 2013 | VPN Log | (g2gips0) #3931: ignoring informational payload, type IPSEC_RESPONDER_LIFETIME |
Dec 6 08:29:09 2013 | VPN Log | (g2gips0) #3931: ignoring informational payload, type NO_PROPOSAL_CHOSEN |
Dec 6 08:29:09 2013 | VPN Log | (g2gips0) #3931: received Delete SA payload: deleting ISAKMP State #3931 |
12-09-2013 06:32 AM
I got it working finally.
Thanks!
