Small branch office network
dnazefg20
We have a small branch office (7 users) that will be moving to a building that has a Wireless Residential Gateway (Model: DPC3829).  This device provides wifi for 2 other tenants on the same floor.  Can we connect another wireless router to this wireless residential gateway device and create our own SSID so that we don't have to use the wifi settings that the other 2 tenants connect to?
I've attached a picture of what the back of the DPC3829 currently looks like.  I am thinking I can plug that yellow network cable into another wireless router and create our own wireless network (obviously off of their internet connection) for our 7 users.
Thank you for your help.
Lovleen Arora
u may but any plane wireless device and run it in bridge mode (shouldd run by default i beleive). Then connect one of its lan port to any one of the lan ports available on the DPC3829 thing.
you are correct in what you want to do, and it can be done no problem.
Please mark answer as correct if it helps.
