Get the latest new and information the November issue of the Cisco Small Business Monthly Newsletter
1292
Highlighted
Beginner
Specify a WAN for Skype using Linksys RV042
Hello
I need to configure the RV042 in a way that Skype would go to WAN1, while other services to WAN2.
AFAIK Skype uses HTTP, so is there a way to specify that without putting all the HTTP requests on WAN1?
Everyone's tags (1)
3 REPLIES 3
Rising star
Re: Specify a WAN for Skype using Linksys RV042
Protocol Binding allows you to bind http to certain WAN port based on destination IP address. But if the destination IP address is not a static IP, it may not work well if users specify the URL.
Beginner
Anyone knows to what IP(s) Skype connects?
If I bind VOIP ports (10000-20000) for WAN1, will Skype communications take place through WAN1?
I have some info you can find on Skype for SIP, which is a service offered by Skype which allows a SIP trunk (like from from the UC500) into the Skype network which is standards based, not Skype proprietary.
http://www.skype.com/business/products/pbx-systems/sip/
