10-08-2012 09:39 PM
Hi All.
I have router with 2x ADSL connections.
Ping time on both connection vary form 20 ms to 1500ms with 2% packet loss with very low utilization over the links.
Upstream provider informed there is nothing wrong with DSLAM or line.
CRC wrrors are no incrimenting, however ES Error on both cards is
ES Errors: 881580 1171
I was unable to find much useful information over it on the internet.
Any ideas or suggestions?
Card type:
NAME: "WAN Interface Card - ATM (With ADSL module) on Slot 0 SubSlot 0", DESCR: "WAN Interface Card - ATM (With ADSL module)"
PID: WIC-1ADSL= , VID: 2.3, SN: FOC11380MRH
NAME: "ADSL over POTS Annex M on Slot 0 SubSlot 1", DESCR: "ADSL over POTS Annex M"
PID: HWIC-1ADSL-M , VID: V03 , SN: FOC13270R4P
Insterface status output :
ATM0/0/0
Alcatel 20150 chipset information
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT) Annex A
ITU STD NUM: 0x01 0x1
Vendor ID: ' ' 'ALCB'
Vendor Specific: 0xDBB0 0x0000
Vendor Country: 0x04 0x0F
Capacity Used: 18% 36%
Noise Margin: 28.5 dB 24.0 dB
Output Power: 12.0 dBm 8.0 dBm
Attenuation: 9.5 dB 8.0 dB
FEC ES Errors: 0 0
SES Errors: 0 0
LOSES Errors: 0 0
UES Errors: 0 0
Defect Status: None None
Last Fail Code: None
Watchdog Counter: 0xC4
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction: 0x15
Interrupts: 2655 (0 spurious)
PHY Access Err: 0
Activations: 2
LED Status: ON
LED On Time: 100
LED Off Time: 100
Init FW: ASW_init_3_8_131.bin
Operation FW: ASW_R3_8_131.bin
FW Source: embedded
FW Version: 3.8.131
Interleave Fast Interleave Fast
Speed (kbps): 0 1536 0 256
DS User cells: 0 125968921
US User & Idle cells: 0 667951660
Reed-Solomon EC: 0 0 0 0
CRC Errors: 0 0 0 0
Header Errors: 0 0 0 0
Bit Errors: 0 0
BER Valid sec: 0 0
BER Invalid sec: 0 0
LOM Monitoring : Disabled
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 0 0 0 2 3 4 4 4 4
010: 5 5 5 6 6 5 5 4 4 4 4 4 4 4 0 0
020: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
030: 2 2 2 2 2 2 2 3 3 3 4 4 4 4 4 4
040: 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4
050: 4 4 4 4 4 4 4 4 2 4 4 4 4 4 4 4
060: 4 4 4 3 3 3 3 3 3 3 3 3 3 3 3 3
070: 3 3 3 3 3 3 3 3 3 3 3 4 3 3 4 3
080: 3 3 4 4 3 3 3 3 3 3 3 3 3 3 3 3
090: 3 3 3 3 2 3 2 2 2 2 2 2 2 2 2 2
0A0: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
0B0: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
0C0: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
0D0: 2 2 2 2 2 2 2 2 2 2 2 2 2 0 0 0
0E0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0F0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
DSL: Training log buffer capability is not enabled
ATM0/1/0
Alcatel 20190 chipset information
ITU STD NUM: 0x03 0x2
Vendor ID: 'STMI' 'BDCM'
Vendor Specific: 0x0000 0x544D
Vendor Country: 0x0F 0xB5
Chip ID: C196 (3) capability-enabled
DFE BOM: DFE3.0 Annex M (3)
Capacity Used: 39% 72%
Noise Margin: 16.0 dB 13.0 dB
Output Power: 19.5 dBm 12.0 dBm
Attenuation: 24.5 dB 25.0 dB
FEC ES Errors: 0 0
SES Errors: 0 0
LOSES Errors: 0 0
UES Errors: 0 0
Watchdog Counter: 0x09
Watchdog Resets: 1
Subfunction: 0x00
Interrupts: 12365 (0 spurious)
PHY Access Err: 0
Activations: 2
LED Status: OFF
LED On Time: 0
LED Off Time: 0
Init FW: init_AMR-4.0.015_no_bist.bin
Operation FW: AMR-4.0.015.bin
FW Source: embedded
FW Version: 4.0.15
Speed (kbps): 0 1536 0 512
DS User cells: 0 10050087
US User & Idle cells: 0 1284561303
Reed-Solomon EC: 0 0 6 5
CRC Errors: 0 6486 4 2413
Header Errors: 0 2211 5 714
Total BER: 0E-0 2573E-10
Leakage Average BER: 0E-0 4010E-11
Bitswap: disabled disabled
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 2 4 6 6 7 7 8 7 7
010: 7 6 6 6 6 6 6 6 5 5 6 6 6 7 8 7
020: 0 0 0 0 0 0 0 0 2 2 2 2 2 2 2 2
030: 2 0 0 0 0 0 0 0 0 0 0 0 2 2 2 2
040: 0 2 2 2 2 4 3 2 2 2 2 2 2 2 2 2
050: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
060: 2 2 3 4 4 4 4 4 4 4 4 4 4 4 4 4
070: 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4
080: 4 4 4 4 4 4 3 4 4 4 4 2 2 2 2 2
090: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
0A0: 2 2 2 0 2 2 2 0 2 2 2 0 0 0 0 0
0B0: 0 0 2 2 0 2 2 2 2 2 2 2 2 2 2 2
0D0: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 3 4
0E0: 4 4 2 3 3 4 4 4 4 3 3 3 2 3 2 2
0F0: 2 2 2 2 2 2 2 2 2 2 2 2 2 3 2 2
