10-07-2011 02:38 PM
I have an SR520 with the following NAT config (full config is below this). Why isn't this working?
interface FastEthernet4
ip address 98.113.43.141 255.255.255.0
ip nat outside
ip virtual-reassembly
no ip route-cache
duplex auto
speed auto
interface Vlan75
ip address 192.168.75.1 255.255.255.0
ip nat inside
no ip route-cache
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 permit 192.168.75.0 0.0.0.255
version 12.4
no service pad
hostname SR520
boot-start-marker
boot-end-marker
logging message-counter syslog
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
crypto pki trustpoint TP-self-signed-544575191
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-544575191
revocation-check none
rsakeypair TP-self-signed-544575191
crypto pki certificate chain TP-self-signed-544575191
certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
dot11 syslog
ip source-route
no ip routing
ip dhcp excluded-address 192.168.75.1 192.168.75.10
ip dhcp pool inside
import all
network 192.168.75.0 255.255.255.0
default-router 192.168.75.1
no ip cef
ip name-server 4.2.2.1
no ipv6 cef
archive
log config
hidekeys
switchport access vlan 75
interface FastEthernet1
shutdown
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
ip nat outside
no ip route-cache
duplex auto
speed auto
no ip address
no ip route-cache
shutdown
interface Vlan75
ip nat inside
no ip route-cache
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 98.113.43.1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
banner login ^CSR520 Base Config - MFG 1.0 ^C
line con 0
no modem enable
line aux 0
line vty 0 4
transport input telnet ssh
scheduler max-task-time 5000
end
10-11-2011 07:07 AM
Oops. Turned out 'ip routing' was not enabled.
