07-06-2010 02:48 PM
Anyone help me get the part number on the AC Adapater and US AC adapter power cable part numbers for the SR520 router? I have a customer that "lost" both and needs a replacement. Any help is appreciated. I looked all over Cisco's documentation for the part number, but could only find CAB-AC2 which only appears to be the AC power cord not the adapter.
Thank you in advance for your help.
Solved! Go to Solution.
07-08-2010 08:51 AM
Hi Michael,
The SR520-FE uses the same power supply as the 870: PWR-850-870-WW1=
This can be used with a 2 pin CAB-AC2 mains lead
Hope that helps,
Andy
07-08-2010 08:51 AM
Hi Michael,
Hope that helps,
Andy
10-11-2017 10:07 AM
Please help me find a replacement power supply for the SR520W-FE-K9 that has both the AC end and the 6-pin end. Thank you!
