Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
852
bmbailey
Beginner
SR520W Wireless guest access via CCA
Is it possible to configure wireless guest access using the built in AP of an SR520W-FE-K9 using CCA. If it is not possible to use CCA, can the CLI be used without breaking CCA functionality such as VPN configuration. Customer requires a firewall between the wireless guest VLAN and the corporate network. Built in AP will be used only for Guest VLAN (SSID) to the internet (WAN Port). No traffic can pass between corporate and guest VLAN.
I searched and found discussion “SR520 Guest Wireless setup” and tried to add an ACL but you will then get an error when building a secure VPN connection using the CCA. “Unsupported Access List”
0 REPLIES 0
