791
Highlighted
Beginner
SRP 527W 12VDC supply voltage range
What is the specification for the input DC voltage range
of the Cisco SRP 527W (nominally 12VDC),
ie is 10 to 14V acceptable?
1 REPLY 1
Highlighted
Hi David,
Thanks for using the Support Community.
Strictly speaking, we only support a +/- 5% tollerance on the input power level.
We haven't tested the range you state, so can't say for sure whether there would be any negative impact if you were to try such a supply.
Andy
