Get
the latest new and information the November issue of the Cisco
Small
Business Monthly Newsletter
As a raw test it is handy for us to ping externally tne WAN port of the SRP 527W, gives us a quick idea of whether it is responding.
Can someone advise how we configure the SRP 527W to allow this? FYI we have the inbulit SRP firewall enabled.
Cheers,
Dale.
Solved! Go to Solution.
Hi Dale, under network setup -> firewall -> firewall filter disable the "filter anonymous internet requests"
-Tom
Please mark answered for helpful posts
-Tom
Tom,
That did the trick - I looked at that setting however it seemed to sound a little wide ranging to just be "allow incoming ICMP requests"
Thank you for such a quick and correct response - solved!!
Cheers,
Dale.
