Announcement“Cisco Design Thinking Workshop”. Cisco Small Business is excited to invite its Silicon Valley customers to an exclusive interactive one-day session between customers and product Managers.  If you are interested in this exclusive workshop, please fill out the Registration Form. For more information, please check out our FAQ
Get the latest new and information the November issue of the Cisco Small Business Monthly Newsletter
1094
Highlighted
SRP 527w Port Forward configuration loss.
Hi.
I was trying to use the uploading of a config.xml file to the modem to configure it (so that I can easily configure a fleet of modems to be the same).
This approach has in the past appeared to work OK, but I recently attempted to use the  same process to save the NAT Port Forwarding settings.  After defaulting the modem, then sending it the configuration most the modem settings are updated as expected, but the Port Forwarding settings are lost.
I would like this function to work, as it would avoid having to configure each modem through the use of the web interface.
Best regards,
     Chris Gibson
