Hi.
I was trying to use the uploading of a config.xml file to the modem to configure it (so that I can easily configure a fleet of modems to be the same).
This approach has in the past appeared to work OK, but I recently attempted to use the same process to save the NAT Port Forwarding settings. After defaulting the modem, then sending it the configuration most the modem settings are updated as expected, but the Port Forwarding settings are lost.
I would like this function to work, as it would avoid having to configure each modem through the use of the web interface.
Best regards,
Chris Gibson
