SRP500 & ProtectLink
chris parkinson
Do the SRP500 routers support ProtectLinkWeb?
Is there any kind of reference sheet that shows what routers do support ProtectLinkWeb?
Or maybe if I re-phrase my question, does Cisco have a Small Business Router that support DSL (direct from the phone company EG SRP526/527) and Protect LinkWeb?
The phone company provided a DSL router, but its, well, junk, and I want to replace the whole thing.
Chris
Clayton Sill
Hello Chris,
     I know for a fact none of the SRP500s support Protectlink web filtering but don't have the documentation on hand. I'll try and see if I can find it and edit this post.
Edit: Alright here are the links.. this one is for web filter:
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps5739/ps5723/ps9952/datasheet_C78-590134.html
This one is for the gateway:
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps5739/ps5723/ps9952/ps9953/data_sheet_c78-502732.html
I hope that helps! and mark this answered as well if you are good to go.
Clayton Sill
vishaalmdp
Hey,
ProtectLInk Gateway is supported by SA 500 series appliances and for Web SA 500 Series Security Appliances, RVS4000 , RV042, Rv082, RV016.
Vishal
