03-19-2012 02:14 PM
Is it possible to send all traffic through site to site VPN using SRP521W (on the other site ASA) ? Lets say, traffic to Internet from branch through HQ - site to site VPN between branch and HQ. I've tried to set up destination crypto policy entry to 0.0.0.0 0.0.0.0 but it's not accepted.
Firmware version is 1.01.26 (003)
BR,
Marek
03-19-2012 03:26 PM
This is not possible with the SRP500 series. Only traffic to a specific remote subnet may be directed via the IPSec tunnel.
Andy
03-19-2012 11:53 PM
Thanks for the fast response. I'm wondering if there is any workaround.
The one I have on mind is to set about 253 static route entries with mask /8 (as far as I remember this is the shortest mask I can use on SRP500 S) and to set up, as a next hop for those routes, some core device in HQ ?
Does this make sens ?
Marek
03-20-2012 02:28 AM
Hi Marek,
It's not possible to create a static route via an IPSec tunnel, so that is not an option I'm afraid.
The only workaround really, would be to have a proxy server at the main site and have all clients use that to access the Internet. You could then use the Internet Access Control feature to prevent local clients from accessing the Internet directly.
Andy
03-20-2012 04:03 AM
Thank you for your answers.
