SRP521W + GRE - works on the router not from the LAN
hi guys,
I use a pretty simple configuration
1 cisco SRP521W
* WAN DHCP
* LAN in a /28
* wireless disabled
* GRE tunnel enabling the access to a /11 network while sharing the local /28
I configured a first router successfully : 10.xx.xx.0/28 , lan ip 10.xx.xx.1 rest afftected as dhcp... and when connecting on the lan i get an IP and can ping the remote network
I tried to replicate the conf on the following routers for different sites
10.xx.xx.16/28 with lan 10.xx.xx.17 and so
but while on the router through the interface the ping through the gre tunnel works ok , on the lan side nothing it just times out...
i'm a bit at a loss so any hint would be apreciated !
Alex
WEIRDER !
if i uncheck the "enable" checkbox on the vpn configuration, the route disappears from the table... but it WORKS from the lan!?!?!
BUT I cannot ping the LAN from the other side of the GRE tunnel....
Andrew Hickman
Hi Alexander,
Did you see the following:
https://supportforums.cisco.com/docs/DOC-23028
Not sure about your second observation - that doesn't sounds right.
Andy
