Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
458
Adamdecker_2
Beginner
SRP526W won't boot correct
Hi, i have a SRP526W and it won't boot correct, nothing is changed, I just turned it off and changed the place, now it won't boot. The POWER/SYS LED flashes and DSL Data LED is solid green!! Can someone olease help me with the problem? THX.
1 REPLY 1
jurodri3
Beginner
Hello Mr. Decker,
Apparently is a problem with the device. On this case I would recommend you to do a factory reset and if does not work contact our Cisco support team in order to open a case.
Diego Rodriguez
Cisco network engineer
Thank you
