SRP526W won't boot correct
Adamdecker_2
Hi, i have a SRP526W and it won't boot correct, nothing is changed, I just turned it off and changed the place, now it won't boot. The POWER/SYS LED flashes and DSL Data LED is solid green!! Can someone olease help me with the problem? THX.
jurodri3
Hello Mr. Decker,
Apparently is a problem with the device. On this case I would recommend you to do a factory reset and if does not work contact our Cisco support team in order to open a case.
Diego Rodriguez
Cisco network engineer
Thank you
