SRP527 wont answer remote ping
graemesmith1960
If I ping my SRP527 from the internet it wont answer.  Any previous ADSL gateway/router I have used had an option to Enable/'Disable Remote Ping' but I can't find it on the SRP527.
As this is a fairly unreliable router, which locks up every few weeks, I want to be able to ping it from the Internet on my ADSL static IP address to see if I need to get someone to restart it for me so I can use my VPN when away on business.  I can't find any option to enable this.  I have remote access disabled as it easier to administer ithe network via VPN but that does not seem to make any difference.
Any ideas?
graemesmith1960
If anyone is remotely interested, that's a pun by the way, I found the setting.
Newtork Setup/Firewall/Firewall Filter - uncheck the 'Filter Anonymous Internet Requests' which is enabled by default.
