03-27-2011 02:16 AM
We have a SRP527W running a ADSL based broadband connection currently, we would like to switch to using FTTC for the internet link.
I have found through these forums how to enable the 4th ethernet port as the WAN interface but cannot see how we can then specify the PPPOE settings required for FTTC.
Is this possible on the SRP527W or the other SRP520 range?
Gary
Solved! Go to Solution.
03-27-2011 04:45 AM
Hi Gary,
The option should be right there for you.
Log in as admin/
Disable ADSL (to enable the 4th LAN port as the WAN interface)
Then from the quick setup (or Interface Setup) page, you can configure PPPoE:
Hope that helps,
Andy
03-27-2011 04:45 AM
Hi Gary,
Log in as admin/
Hope that helps,
Andy
03-27-2011 09:16 AM
Now I feel silly, it was right under my nose.
