Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1524
CytringanLtd
Beginner
SRP527W fixing DHCP address's and firewall source rules
In my quest to find a decent ADSL router for VoIP I found the SRP527W and so far it has been the best performer from a range of netgear, thomson and zyxel boxes.  I do however have two questions,
1) how to fix DHCP leases on LAN address's
2) how to specifiy source ip in firewall rule
Note:
I currently have 1 computer on the LAN interface, VLAN1
* 192.168.15.100
and
2 VoIP phones on the LAN interface, VLAN100
* 192.168.100.100
* 192.168.100.101
The three address's are assigned by DHCP server with lease times around 20 days.
I would like to fix the DHCP leases of the three devices, for example so some port forwarding rules can be made with confidance that the rules will not point to another device in the future.
from PVC0 -> 192.168.15.100 Port 3389 for remote desktop
from PVC0 -> 192.168.100.100 ex.port 5881 to int.port 80 for web-gui of voip phone
from PVC0 -> 192.168.100.101 ex.port 5882 to int.port 80 for web-gui of voip phone
ideally I would like the rules to act like this, limiting only myself from accessing these ports (from my remote site)
from interface PVC0 where source is ip 12.34.56.78 -> 192.168.15.100 Port 3389 for remote desktop
from interface PVC0 where source is ip 12.34.56.78 -> 192.168.100.100 ex.port 5881 to int.port 80 for web-gui of voip phone
from interface PVC0 where source is ip 12.34.56.78 -> 192.168.100.101 ex.port 5882 to int.port 80 for web-gui of voip phone
Hopefully that makes sense, I appreicate any help you can give,
Kind regards
Paul
1 ACCEPTED SOLUTION
Andrew Hickman
Hi Paul,
Thanks for using the Cisco Support Community.
Regarding your two questions:
1. Yes - it is possible to configure DHCP static assignments.  Use the DHCP Server Rule configuration page and click the "Show DHCP Resevation" button to assign.
2. Unfortunately it is not possible to configure source address list rules for the SRP520.  (This is possible on the SRP540 for others reading).
Andy
1 REPLY 1
Andrew Hickman
Hi Paul,
Andy
