02-21-2012 05:59 PM
Hi All,
We have 2 sites with 2 internet connections at each site. All are SRP527w routers. 1 is for internet and 1 is for a site to site VPN as shown below:
192.168.2.254 Public IP 120.10.25.35
192.168.3.254 Public IP 120.10.25.36
(All IP's are examples not our IPs)
Currently we are using Static Routes on the PC's so they can access each server no matter what site they are at. I have looked at using the Static Routes section on the SRP's but cannot get it to work. Was wondering if someone has done this before and if s what i might be doing wrong.
Cheers,
Ross
Solved! Go to Solution.
02-22-2012 09:58 AM
On your PCs/servers you must configure the default gateway only, in your case the SRP used to connect in Internet.
Server 1 Default Gateway: 192.168.2.1
On this SRP you must add a static route like this:
ip route 192.168.3.0 255.255.255.0 192.168.2.254
You must replicate the config for server/site 2 and adjust ip addresses.
Use ping and tracert for test.
Regards.
02-22-2012 09:58 AM
Regards.
02-22-2012 02:01 PM
Thanks Daniele. Works perfectly now.
