04-14-2013 09:37 AM
I've set up port forwarding from an external port (9000) to an internal port (80) on our SRP541W, and for some reason, it's not working externally. If I access the public address from within the internal network, it works properly. Any ideas?
Solved! Go to Solution.
04-15-2013 02:07 PM
Hi Adam,
When you configured the static IP address on the camera, did you set itd default gateway address to 192.168.15.1 (the SRP500).
Are there any other configuration settings in the camera that perhaps limit access to local clients?
Andy
04-15-2013 03:31 AM
Hi Adam,
You don't have an advanced firewall rule that is blocking port 9000 do you?
Andy
04-15-2013 06:32 AM
I do not.
04-15-2013 06:59 AM
Hi Adam,
This feature has always worked for me in the past.
Has your web server been configured with a default GW address?
Could you paste a screen shot of your rule configuration page? The following works for me:
Andy
04-15-2013 07:05 AM
I'm not sure what a GW address is... It's a security camera, and it's set to a static IP.
I've attached the screen shot you requested here.
04-15-2013 02:07 PM
Hi Adam,
Andy
04-15-2013 03:57 PM
You nailed it...I had the gateway set incorrectly. Thank you again for your help!
