SRP546W
kittenpiggy
Beginner
Beginner
Hi NetPro.
Does anyone knows the Product Number of SRP546W ? as i can't find from Dynamic Tool and Multi-line configurator.
Can anyone help ?
Thanks.
Kitten.
Andrew Hickman
The SRP500 series are available on the dynamic configuration tool - however, as they are only available through our distribution partners, you will only be able to see them if you have access to a Wholesale Price List.
If you do have access to the WPL, then ensure you select it from the configuration tool search page first.
BTW - the only configurable option on the SRP500 portfolio is the power cord for the SRP540 series.
Hope that helps,
Andy
Hi Andy .
Thanks for your information . i am from cisco partner company (Platinum) . however, i tried to generate the BOM list from Dynamic tool whereby choosen the Small Business Pro. but, seems like not able generate accordingly. you may see from attachment.
Kitten
I see that you are still using a Global Price list.
Using a WPL provides product information.  See below.
Andy
